Can someone tell me where this bolts to?
Old Aug 30, 2017 | 02:23 PM
Bmurray's Avatar
Found this just hanging under my intake manifold. It's part of the Evap system isn't it? If anyone has a picture or diagram of where it is supposed to bolt up that'd be great. Hell if you know the bolt sizes that it uses it would also help because I assume they backed out and flew off since it's not bolted up.
Old Aug 30, 2017 | 02:57 PM
4b11slayer's Avatar
Thats the egr solenoid. Bolts up to the right side of the manifold "back under side". With a 10mm
Old Aug 30, 2017 | 02:59 PM
4b11slayer's Avatar
Old Aug 30, 2017 | 03:26 PM
Bmurray's Avatar
Thank you!
Old Aug 30, 2017 | 03:29 PM
heel2toe's Avatar
It attached to the bracket that supports the IM. Chances are the previous owner pulled that bracket off vs your theory of the bolt backing off.
Im sure you can come up with a clever way to get it bolted on back there. There are 2 bosses on the IM where the bracket would attach so maybe just bolt it to a piece of flat stock and bolt that to the IM. Or just let it hang...
SIMSSEGA
Aug 23, 2004 11:04 PM
MarcioTheGreat
Aug 16, 2004 02:14 PM
Tofurky
May 12, 2004 02:12 PM
redbeard
19
Nov 12, 2002 03:59 PM
