02 houing downpipe advice..
I have tried to research and cant find a direct answer on what 02 housing and or downpipes work with the fp black turbo. I know STM and MAP have one and as nice as they are they are crazy expensive. If I have to buy one of those two then that is what I will do but if there is an alternative I would be interested in hearing your thoughts.
The problem is the wastegate. If you want to just run a dump then you can use this from FP and just bolt it up what ever DP. If you want to recirculate the wastegate exhaust then you will need something fancy.
http://www.forcedperformance.net/mer...e=Lancer-Turbo
Jasoob
Jul 4, 2012 02:14 PM
churchja
17
Nov 16, 2010 08:15 PM
evolutionEvo
Aug 11, 2008 02:20 PM
