Camshaft Angle Sensor Malfunction?
Well as I was driving the other day I made a broken u turn with the clutch fully pressed and about to go into 1st the car stalls...
I tried to start the car and it took about 20+ seconds of trying to start it... than my SES light goes off...I come back to my neighborhood and borrowed a code reader and it read Camshaft Angle Sensor Malfunction.... has this happened to anyone?
yes this happened to me before..... This is when my stalling problem started....?.... The code never came back....
SAME EXACT THING happened.... It took around 30 seconds b4 it fired back again...
Re: Camshaft Angle Sensor Malfunction?
Eric
When I installed my cams, I didn't put the cam angle sensor wiring harness back on tight, and the car wouldn't fire up. After I reconnected the harness, it was fine. Check the wiring to the cam angle sensor, make sure it's tight. It's on the front driver's side corner of the engine.
