HELP my evo iv driving me crazy!
Old Oct 11, 2018 | 03:43 PM
stalkn's Avatar
Angry HELP my evo iv driving me crazy!
ok so I recently imported a 98000km Evolution IV from Japan
Stock apart from:
3" cat back
aftermarket airfilter in OEM airbox
HKS Seq BOV
Car has a weird miss-fire that Actually sounds like a boost or fuel cut to me. It goes flat as a pancake and pops almost like antilag
It happens right at the transition between Vacuum and boost .
So far I have replaced the spark plugs with BPR8ES gapped to 0.6mm and new Coils.
this made no change AT ALL so after help from MR Google I replaced the Exhaust Cam Sensor.
First two test drives of about 3-5km each with new sensor and the car was PERFECT.
no miss stutter or hesitation and car made boost as one would expect all they way through rev range
Third test drive about 30 mins later and car was instantly back to the exact same problem, fine off boost (maybe a very very slight uneven Idle) but a huge issue at the transition which doesn't go away ie cant be revved through but disappears if I let engine drop back into Vacuum
What the hell is going on ??????
Old Oct 12, 2018 | 11:06 AM
4G63Rules's Avatar
I had the same problem you are referring to with my IV and I replaced everything:
cam sensor
water temp sensor
crank sensor
MAF
injectors
coil packs
But what eventually fixed it for me was two bad spark plugs. After that, car ran like a top! I would try the coolant sensor and maybe clean the MAF. Check your injector clips for corrosion. Make sure your timing is good. Hope you find your issue.
Old Oct 14, 2018 | 01:34 PM
stalkn's Avatar
thanks for the ideas I will look into those as well
Plugs and coils are new and made no change at all but i might close the plug gap up to 0.5mm
Whats got me completely confused is how a new cam sensor fixed it momentarily!
