Seal between TC and Transmission (and rear differential bearings)
Old Nov 11, 2018 | 05:38 AM
Wajeb Wahab's Avatar
I have recently bought a NON ACD transfer case, opened it up for inspection and everything was clean, unfortunately only one seal was broken and it was the 2 way seal that is placed between the Transfer Case and Transmission.
I can't manage to find the seal anywhere and when I do its pictured in a way that doesn't look like its the same.
Does someone know the seal I'm talking about?
And where can I find the bearings that go inside the rear differential? I searched everywhere, I can't even get the serial numbers of those parts!
Old Nov 11, 2018 | 08:36 AM
kaj's Avatar
kaj
https://stmtuned.com/collections/evo...al-oem-evo-8-9
As for the bearings, I'm too lazy to Google that.
Good luck!
Old Nov 11, 2018 | 09:24 AM
Good luck!
Its been since the begining of the weekend and I'm searching for the rear Bearings, found one but can't find the other one, I was told they are 4 by my mechanic so the one I'm finding isn't enough, even searched parts number sticky thread still nothing.
I already bought the one you linked me to from yesterday but I was trying to make sure the ACD and Non-ACD aren't different... Just making sure...
But thanks anyway and if you can point me to the bearings (all of them) cause I can only find one, would be great.
Old Nov 12, 2018 | 12:07 AM
2006EvoIXer's Avatar
This is in my ACD TC rebuild kit
Maybe ACD and Non-ACD TC both uses the same part?
Old Nov 19, 2018 | 06:19 PM
TomekEVO's Avatar
If I were you I'd replace all 3 when I am in there for a peace of mind. There are cheap and you don't want it to leak when you put it all together. I replaced all 3 when I did mine
Old Nov 23, 2018 | 03:37 AM
Yes they turned out to be the same!
Old Nov 23, 2018 | 03:38 AM
​​​​​​I replaced only the mentioned one and behold I got a leak! From the oring behind it I went in again and did everything so over again!
If someone is changing this do all the rings and seals!
