Misfire ??? tune related?
Old Jan 6, 2019 | 06:00 AM
audiofan's Avatar
I´m having a constant misfire between 4k and 5.5k rpms at half throttle (around 8/10 psi), below that I can rev no problem, WOT no problem. Tried COP and stock coils, new plugs, smaller gap, could this be tune related?
Can too much fuel or too lean condition cause a misfire? or too much advance/retard timing cause a misfire?
Everything seems normal, wideband shows good afr, timing is 14/17 when misfire happens.
Thanks for your reply
Old Jan 6, 2019 | 07:08 AM
ctfpevoVIII's Avatar
So your saying while in that rpm range 4-5.5 your afr’s are fine but it’s misfiring?? That seems odd, also what fuel are you running and regardless 14-17 degrees of timing seems way too high at that rpm range.
Old Jan 6, 2019 | 11:20 AM
audiofan's Avatar
Fuel is 93oct pump, this is at really low boost 5/10 psi half throttle, should I retard timing in this area?
Old Jan 6, 2019 | 11:49 AM
Teal2nnr's Avatar
the timing shouldn't be your issue. At only 5-10 psi that timing sounds fine. Misfires can be lots of things. Bad MAP sensor, bad cam position sensor, boost leaks. There's lots of threads out there on things to start trying.
