BBK Full Wastegate
Old Feb 19, 2019 | 08:25 AM
blackline's Avatar
5 Year Member
BBK Full Wastegate
Does anyone know if the BBK full uses a Evo 8 or Evo 9 wastegate? I tried reaching out CBRD but I'm unable to get a response.
Old Feb 19, 2019 | 09:56 AM
heel2toe's Avatar
Its based off an IX so the IX WG is the one you're after. Do you need one as I have one kicking around that actually came off my BBK Full before I opted for a higher pressure unit?
Old Feb 19, 2019 | 10:19 AM
blackline's Avatar
5 Year Member
Thank You!!!!
I'm after a 22psi turbo smart wastegate for my BBK.
Old Feb 19, 2019 | 11:09 AM
heel2toe's Avatar
Ahh gotcha. What are you targeting for boost with it? I switched to an 18# WG back when I had my BBK and was able to achieve 33# with it. Im sure I could have ran more boost but was out of injector and stock motor at the time so didnt want to push it. My point is seems like that might be a fairly stiff actuator.
Old Feb 19, 2019 | 11:26 AM
blackline's Avatar
5 Year Member
Looking to hit 30#ish. Tuner recommend I get the 22psi
Old Feb 19, 2019 | 12:03 PM
kaj's Avatar
kaj
You would need a minimum 15psi wga, so 22 is fine and probably easier to control @ 30.
Old Feb 19, 2019 | 12:10 PM
heel2toe's Avatar
If thats what your tuner wants then go for it. Personally I think that is too stiff and might be a lil challenging to control the spike. General rule of thumb is you want to have wg spring around half what your target boost is so given that I'd opt for an 18# wga.
Old Feb 19, 2019 | 01:21 PM
blackline's Avatar
5 Year Member
Thanks for the input fellas!
