No fuel- no spark- replaced crank position sensor (Please Help)
Old Mar 13, 2019 | 07:02 PM
Davidson18's Avatar
Exclamation No fuel- no spark- replaced crank position sensor (Please Help)
Have a 03 evo 8. Mostly stock engine component evo (exhaust) (maybe cams/ past owner questionable) Driving home from the store and car dies while driving. Have no spark/fuel. Check codes with scan tool and get P0335 (twice). I pull it apart and my crank position sensor is broken (missing the metal piece) and I replace the sensor. Car is still no start like before with no fuel/spark. All fuses are good. Any ideas?
Old Mar 14, 2019 | 08:39 AM
barneyb's Avatar
Are you sure the crank sensor isn't broken again? In other words, what broke it in the first place?
Old Mar 15, 2019 | 06:22 AM
Davidson18's Avatar
Balance shaft belt broke, and broke the crank sensor. I replaced the sensor again (was faulty sensor) and swapped the fuel pump. I am currently getting spark now, but car starts and dies instantly.
