Smoking after Wot/boost Help
Old Jul 21, 2019 | 11:26 AM
Dylan Tenney's Avatar
Hello My setup is a bw 362 with a built block and stock evo 8 head. After getting into any boost the car will puff out white smoke which smells like oil. This just started happening after one pull, i was tuning the car all was going well at 28 psi. I go to turn up my hallman mbc and the next pull i end up at 16 psi. The boost kept going down so i changed the mbc to a grimmspeed. Now the turbo wont go past 16psi and will dump smoke out after i let off the gas. I cleaned the pcv and have concerns that may be the problem, im also not running a catch can system. I have a dw 350lph and 1000cc injectors maybe im running into fuel failure. Another thing im considering is that i blew a seal in the turbo because when i originally installed the turbo the drain was horizontal (yes i know this was idiotic) But i fixed that and the drain is going strait down into the oil pan. Maybe oil is still built up in the turbo? Anyways any help or pointers would be greatly appreciated Thanks.
