Boost pressure help
Old Aug 18, 2021 | 06:17 PM
4g63tevo's Avatar
Boost pressure help
My car is currently tuned for 27 psi, but I have never been able to get to it due to boost leaks.
I have fixed many boost leaks, but still haven't solved the issue
The weird thing that I have noticed is that if I turn the boost down to 20 it cannot hold it, but when I turn it up to 27 it can go up to 25 then not hold it. I do not understand why it can't hold at 20, but then can push up to 25 and not hold it.
any advice helps thanks
Old Aug 18, 2021 | 06:25 PM
Jonno99's Avatar
Where are the current boost leaks?
Old Aug 18, 2021 | 06:55 PM
4g63tevo's Avatar
To my knowledge there are none after boost leak testing it it can go up to about 30 psi before bov gives out.
There is air coming out the tube that is connected to the valve cover on the right side. Not sure what this is for but it leads to 2 air filters and a hose that isnt connected to anything.
The air comes out of the air filters themselves.
Old Aug 19, 2021 | 04:18 PM
hutch959's Avatar
not sure what "tuned to 27 psi mean"...
you mean that was the target?
just because it was the target doesnt mean thats what you actually see.
is it a stock turbo? build?
stock turbo's wont hold boost up top..
Old Aug 24, 2021 | 06:50 PM
osetsky's Avatar
Would the thing with 2 filters maybe probably be a catch can?
Raceghost
Oct 18, 2009 12:53 PM
$ilverEvo
Aug 29, 2007 05:07 PM
El Boricua
10
Mar 29, 2005 05:01 PM
pkjing
Oct 28, 2004 06:56 AM
