Oil pressure drops at high RPM?
If you have a lack of oil pressure at wot that’s a large concern. Going to a thinner oil is going to lower pressure.
You may want to cut open the oil filter and check it incase there is an issue.
I would still suggest measuring oil pressure at the oil filter housing moving forward. That is where most measure it so you can compare apples to apples.
20-50 is thick oil and takes time to warm up. I realize it’s thick oil but high HP 4g63’s have run it for years with good results.
You may want to cut open the oil filter and check it in case there is an issue.
yeah, this is true. Here in southern Ut the weather will be nice and warm and then its ice cold. I have always run 20w50 oil and again never no issues with oil pressure while doing WOT but here it's a lot different than SoCal! It's kind of scary cause at times driving the car and hearing a loud tick thinking maybe a spun bearing but I have already verified it's my loud *** injectors.
Yep, I am running FID 2200's which are the Bosch and idk I guess I never really noticed how loud they are until the other day dealing with the oil pressure issue. For now, I am going to go down to 10w30 and see what change there is if any. My oil clearances are not super crazy so 10w30 will do just fine.
Its a performance engine ,not a prius. 5w40 would be the minimum on an 80's rally engine making good oil pressure and power. There is also 5w50 oil available.
Most of us run 20w50 and let the car warm up a bit before going out. Then another 15 minutes or so to get the drivetrain warm before making a pull. For high hp its a proven combination.
May want to keep reading the forums or call a few evo shops. You spent alot of time and money on a rebuild and 60psi of oil pressure at wot isn't going to end well. What did your last engine make for pressure with the sensor in its current location?
So the title of the thread is "oil pressure drop at high rpm". Suggestions were made and Viscosity came up on startup. Your first step is going to go down to 10w30??
The weather here gets cold so changing to a different viscosity will help me rule oil viscosity. I have oil pressure it’s not like it down it’s the teens at all times. And 10w30 or even 10w40 and my oil clearance are going to work perfect no issue. I don’t need to read more! On start up I am getting 80+ psi of oil pressure and a warm motor I’m still getting 25/30 psi. WOT and seeing 60 psi yeah it’s not the best but I don’t stay in the pull seeing the oil pressure drop like it does.
Oil clearances were set at .025, I just ordered a new oil pump, and I am going to go to a little bit less Viscosity and see if there is any change! cold start like 1st start of the day I'm sitting at 80+ once I get some temperature will sit at mid 70's and full warm at idle 25/30 psi. WOT high 50 low 60's.
If you warm the car up and rev it to 6000rpm in the driveway, is it still 55-60psi?
Or is it higher?
I want to know if it's G-Force induced, or if it's low at high rpm all the time.
Good question, I am not to sure I haven’t done that kind of test but I will and post the results.
Bringing this back as I'm having almost exact same things happen and want to see if you found anything interesting! I was running 10w40 and now have 15w40 in and I get 100+psi at idle on cold startup, warm idle is between 25-30psi. When cruising it is around 65-70psi. Goes to about 85psi when I go WOT and then around 7,800rpm-9k it slowly drops into low 70s. Get back under that RPM after I let off then it is back to around 70psi. It did this before and after adding my STM oil cooler just for reference. I have pulled my last 2 filters apart and there is no metal. Also pulled the pan for kicks and all rod bearings are perfect
Important details:
-Fresh engine build (less than 2k miles)
-Balance shaft delete (piston oil squirters still in)
- Brand new OEM oil pump (when engine was built)
- All hidden oil galley bolts sealed such as behind the engine mount
- Brand new OEM Buschur baffled oil pan (never been pushed on)
- Kiggly HLA
- GSC zero tick lifters
- AEM 150psi sensor on oil filter housing (not back of engine block)
I bought a whole new OEM gasket kit for the pump and OFH and sprayed then with copper spray to also make sure nothing was getting past the gaskets for some reason. Didn't really do anything.
It's just weird because as long as I am under 7.8k the oil pressure is great. Did you ever figure anything out on yours?
.Important details:
- Kiggly HLA
Important details:
- Kiggly HLA
.Important details:
- Kiggly HLA
