Upgrading to FP Red tips.
Old Aug 5, 2023 | 01:09 AM
DKE7's Avatar
Hey guys, I've got an 2.3L Evo 7 Stroker and was wondering what I should also add alongside the upgrade to an FP red, I'll attach a photo with what's currently on the car. The car's making a steady 300kw on E85 and I'm gonna add in a Link G4+.
Thanks! <3
Old Aug 7, 2023 | 08:01 AM
schuhie's Avatar
Given that you are running a stoker, I'd be tempted to go to an FP black honestly.
That said, I have a similar setup to you but on a 2.0 with a red and its great. I don't see anything missing in your mod list that I would upgrade outside of maybe the clutch when it gives up. That Exedy is going to be feeling the pressure at the power levels you can get to on the red. I ended up going from an ACT HDSS to an Exedy twin.
Old Aug 14, 2023 | 06:56 AM
M4Lki3r's Avatar
Veteran: Marine Corps
Do you have any head work done? Porting? Bigger valves? I'm unfamiliar with those cams, but they might need springs.
Stock intake? Is your intake ported?
Stock throttle body? Is it ported? I would recommend also doing the valve seals as well.
Stock exhaust manifold? Is it ported?
Old Aug 14, 2023 | 10:43 AM
schuhie's Avatar
ooo the springs are a good question. I missed those.
Also replacing the throttle body seals would be a good idea if they haven't been.
I didn't port anything on my setup. This is a highly use case specific thing. Porting will make more power at the top at the expense of spool in my understanding.
sam0329
Jun 2, 2013 05:24 AM
novaspyder87
11
May 16, 2013 02:02 PM
iloveevo
May 30, 2011 09:42 PM
DDATuned
Jun 27, 2009 03:56 PM
Pure Playaer
28
Feb 3, 2009 09:52 PM
