Evo cranks but doesn’t start
Old Sep 2, 2024 | 03:32 PM
Adbraxx's Avatar
I replaced the spark plugs, crankshaft sensor, intake cam sensor, battery and starter. I have spark and fuel. Ever since I’ve done those parts replacements the issue has become intermittent and no longer have a check engine light (p0335), also the starter sometimes clicks but it doesn’t crank. This brakes my hart I’ve put a lot of work into this car spent a lot of money I don’t know what else to do I thank you guys in advance for the help also attached a picture of my evo.
Old Sep 4, 2024 | 12:50 PM
CurseDSM's Avatar
That code is for the crank position sensor. Check to see if you have power to it being it involves the circuit itself.
Old Sep 5, 2024 | 10:12 AM
Adbraxx's Avatar
the code was being generated by me cranking over an over, the car didn’t start because it was flooded. I still have an intermittent starting issue. I replaced the ignition switch and it got better but it still just clicks from time to time. I’m still trying to figure it out
Old Sep 5, 2024 | 10:18 AM
Adbraxx's Avatar
Apparent the code generates when you crank over and over and the car doesn’t start, the car was flooded and because I have 1600 injectors it floods right away. Since the starter clics the pump sends fuel and when it actually cranks it’s not starting because it’s flooded. Long story short it’s a starting issue.
Old Sep 7, 2024 | 10:00 AM
ViciousLSD's Avatar
you might need to try and rewire your starter relay. clicking starter issues is quite common on these cars.
in the meantime you can "hotwire" the starter by connecting 12v to terminal5 of the starter relay location
Notevoepz
Lancer Troubleshooting
11
Sep 12, 2022 06:47 PM
Joshua Sutten
Aug 6, 2022 01:02 PM
LuceyMane
Jun 15, 2021 05:27 PM
EvoRix
Dec 26, 2017 02:21 PM
benny23
Jul 31, 2015 10:57 PM
