Need help with planning a swap
Old Feb 10, 2026 | 08:01 AM
MrYeoh's Avatar
[size=16px]The 8th gen in Malaysia are all grey market so coming across a manual is difficult.[/size]
[size=16px]Easy and cheap way to get a 4G63 or 4G64 here is outta a Sonata/Optima[/size]
[size=16px]What would it take to swap a 5MT? Any gearboxes to reccomend? Any holes that needed to drilled for the clutch pedals?[/size]
[size=16px]What are the best non EVO spec rear disc brakes I cant fit into it if does not come with disc? Ralliart or Cedia?[/size]
[size=16px]Any links to other post with any correct information would be helpful. Thanks[/size]
Old Feb 11, 2026 | 09:52 AM
RobbieOh's Avatar
5 Year Member
I can't help you other than tell you to spend hours cross-referencing part numbers to see what's what and what might fit. Check all the models you can. This is what we did back in the day for Honda to figure out what moves around. Maybe someone else will chime in with real information.
MrYeoh
Feb 10, 2026 08:00 AM
MrYeoh
Apr 13, 2025 10:13 AM
evo6 istanbul
Nov 1, 2009 06:07 AM
viet_tak
Lancer Engine Tech
18
Aug 12, 2005 10:46 AM
kerupt
Oct 2, 2004 07:00 PM
