Downpipes and emissions....
Old Apr 26, 2004 | 06:15 PM
kero's Avatar
Will replacing the downpipe affect my emissions? Is it only if I replace the catalytic converter? Keeping the stock cat should be okay right?
Old Apr 26, 2004 | 07:20 PM
1QWKEVO's Avatar
visual it will pass, emissions it might not... turbo will have a slightly different responce to throttle
Old Apr 26, 2004 | 07:26 PM
tweakdsm's Avatar
i would install stock downpipe and cat back on, you can leave the catback if you wanna pass.
Old Apr 26, 2004 | 07:45 PM
MalibuJack's Avatar
It really depends on what your inspection station looks for.. since the car is AWD, some states don't require a dyno (rolling road) sniffer check. In that case, its likely it would pass without problem.. To be honest with you, it probably would pass with quite a few modifications since we're really not making the car run dirtier (if you leave the catalytic converter on, or get a high performance one). Its tough because some states require only an OBD-II check.. some have a smog check, some have both, some have safety only for the first few years.. etc.
