Ignition Issues?
Old Apr 30, 2004 | 06:57 AM
QuickEvo's Avatar
Ignition Issues?
My engine is turning over, but it takes a while for it to crank. I mean like 10-15 seconds before it fires. Any ideas on what could be causing this?
Old Apr 30, 2004 | 11:45 AM
QuickEvo's Avatar
It's getting electricity. Everything powers up. It's alomst as if all the fuel that is in the line/rail is not pressurized. Like when you change a fuel pump and you have to release all the pressure in the rail. It's almost like getting the pressure back into the rail everytime I start the car after it's been sitting for a while. Any ideas? Anyone?
Old May 1, 2004 | 04:43 PM
mayhem's Avatar
Can you perform a leak down test? Maybe it's getting a little flooded after sitting a while.
Old May 2, 2004 | 05:13 PM
QuickEvo's Avatar
Thanks Mayhem, I will try that tomorrow to see what comes up.
Old May 2, 2004 | 05:22 PM
SidewaysEvo's Avatar
u know that same thing happend to me. I am thinking its because of the weather. it was like 95 degre's over here. So i stalled then i tryed to start it back up again it wouldn't start. but i stopped cranking and about a min. later it started again. i don't know strange.
Old May 3, 2004 | 11:56 AM
QuickEvo's Avatar
Interesting. It only happens to me when the car has not been operated in 6 hours or longer. It's about 50 degrees here so I'm not too sure about the heat affecting it either. It's very finicky. When I left my office a few minutes ago it cranked right up. Oh well, doing the leakdown test later to see what's up. Thanks for the suggestions so far, and if anyone has more suggestions feel free to chime in.
Old May 3, 2004 | 04:33 PM
MalibuJack's Avatar
have you done any modifications to the car yet? (I'm not sure if you mentioned it before)
My car does it in cold weather, I went with colder plugs, and it seems to take a bit longer to fire on cold days.. fouled plugs can also have the same effect. If you do a leakdown test, check your plugs, and adjust the gap to a .026 or so.. it should help a little on stock heat range plugs if their not really fouled.
Old May 4, 2004 | 02:56 PM
QuickEvo's Avatar
My car is modded, and I do have colder range plugs. When it's cold outside it fires right up. When it's warm it takes a while to fire up. I will check the plugs after the leakdown test to see what's up. I did gap them to .27 when I changed them out. Hopefully they arent fouled. Damn Iridium plugs are expensive. I've tuned myself to 11.5 so they should be alright. I'll let everyone know. Thanks again for the responses.
