To all with Buschur racing Turbo back Please Read
Old Feb 10, 2005 | 09:28 AM
  #61
TheGVR4kid's Avatar
Is there any sort of trade-in program if you have the original version exhaust?
Old Feb 11, 2005 | 10:17 AM
  #62
David Buschur's Avatar
There is not trade in on the old exhausts. I can attempt to fix them if you call and we figure out what is wrong.
As for the muffler sticking out and hitting the sway bar. If it is an aftermarket sway bar it could be possible. Otherwise it is in the adjustment and if the system has been bought here within the last 2 months it has to be installation error and that is hard to believe. It is just too easy to do now.
The tip sticking out tells me the system is not slid together far enough, that is probably the problem.
David Buschur
www.buschurracing.com
Old Feb 11, 2005 | 12:16 PM
  #63
lancealot72's Avatar
I actually bought the system back in nov. I was waiting till the weather got a little better and i moved into a house with a garage to put it on. So, if you guys have made any changes in the last two months, then let me know please. I have taken this exhaust off twice now and fiddled with it numerous times and no luck. I am willing to mess with it some more to get perfect firment. I was just searching for some quick insight. Its the stock sway bar by the way. If i rotate it away from the sway bar a little then the muffler is not aligned.
I will get it sooner or later.
Old Feb 11, 2005 | 12:57 PM
  #64
Rotate it away from the sway bar and then rotate the muffler the opposite way, this should line it up.
David Buschur
Newby81
Feb 26, 2017 01:10 PM
hermesevo8
Sep 20, 2015 03:42 AM
mikespike2
May 14, 2007 09:58 AM
Chris@nolimitmotors
Dec 8, 2005 06:23 AM
David Buschur
Aug 26, 2005 08:24 AM
