ACD - Different setting on engine start
Old Nov 13, 2001 | 08:42 AM
AntsEvo's Avatar
Does anyone know of any way to have the ACD setting on the EVO come on for say "Gravel" setting, when starting the engine.
Old Nov 15, 2001 | 12:06 PM
dedeffa's Avatar
I'm sure you could frig it, I always assumed it just remembered the last setting, but then again I don't own a 7 so how should I know. Are there WSM out for the 7 yet? you might find a kludge in there....
Ryan
Old Nov 15, 2001 | 12:31 PM
AntsEvo's Avatar
err, thanks for that Ryan
But I was just about to edit it - just came home from work and switchen it to gravel, came home and went back out again about an hour later and low and behold it stayed on gravel.....I'm sure it never used to do that!!...must be the cold weather
Old Jul 31, 2005 | 03:46 AM
EVO7's Avatar
wow you have posted in here every minute that is amazing...
Old Jul 31, 2005 | 05:36 PM
oguratevo's Avatar
It should stay in whatever setting/mode you have before you shut off the engine, eg. Gravel etc.
Old Nov 19, 2005 | 11:07 PM
g3mccotter's Avatar
yea man its not tha cold weather it does stay in tha same settin as when you turned it off. hey does anyone know if its bad to change modes when your drivin, or should you be goin slow or stopped. pm if you know.
james
Old Sep 27, 2010 | 02:41 AM
4CEF3D's Avatar
Does anyone know if theres something wrong when all three options are on?because after a few min of driving i noticed all three(tar,gravel,and snow)lights comes on?
Old Sep 27, 2010 | 04:52 AM
drocksmash's Avatar
This means there is an issue with your ACD system... LOTS of threads on it, did you change your ACD fluid lately? if so was it bled properly?
Old Sep 27, 2010 | 07:36 AM
Dallas J's Avatar
Veteran: Army
james
It not like a 4x4 transfer case. All the different modes do is change the pump pressure profile. You can change it at any time.
