My CEL just came on!!!! :(
Old Jun 29, 2004 | 06:50 PM
v8killer's Avatar
I was pulling into the gas station and because of my BOV my car stalled. It always gets close but doesn't ever really stall. Well this time it did, and it took a couple of truns before the engined fired up. I pulled up to the pump and did the refuel thing. Then got back in started the car and the CEL was on, and has been on for the rest of the evening.
I made sure the gas cap was on tight, and yes it was aamco 93 octane! It is running fine too. I even turned the car off for awhile and then cranked it up, but the CEL was still there.
Any ideas? Do you thing this has something to do with my HKS BOV, I do have the recirc kit installed.
Old Jun 29, 2004 | 07:06 PM
nastea's Avatar
you can clear it, it might be a MAF error, take it to autozone and check the code. if you were around here i'd let you use mine anyway... check.
if you want you can clear it by removing the neg. battery terminal for 3-5 seconds, it clears the code, but won't reset your clock/radio and other stuff.
Old Jun 29, 2004 | 07:53 PM
v8killer's Avatar
i was thinking that, thanks
Old Jun 30, 2004 | 05:36 PM
v8killer's Avatar
It is off now, I removed the Neg terminal for like 15 sec , then it was gone. thanks
Old Jun 30, 2004 | 07:02 PM
RobS's Avatar
Nastea: What kind of scan tool are you using? Can you use any obd2 reader to check and clear codes? I know that on my S4, disconnecting the battery will leave a soft code in the ecu. This lets the dealer know that the battery has been disconnected for whatever reason. I wonder if it's the same with the Evo...
