Fix for your CE light! o2 sim.
Old Jul 1, 2004 | 11:01 AM
tweakdsm's Avatar
You can order o2 sim. from http://www.o2simulator.com/
for $30 shipped, i thought i would just share with you guys...
later
Old Jul 1, 2004 | 11:09 AM
prowler's Avatar
Does it come with good directions, on which wires to splice?
Old Jul 1, 2004 | 11:47 AM
Noize's Avatar
EvoM Administrator
Or you can go to Autozone and get two gasketed 18mm antifouler extensions, then drill the outer/back one with a 1/2 inch bit and never get a cat inefficiency/slow rear O2 CEL again for only $4!
Old Jul 1, 2004 | 12:13 PM
MaxR's Avatar
Does that work with a stock catback? I have a Helix Test Pipe with similar mechanical fix and a stock exhaust but I still get the CEL. My theory is at full throttle I think the stock catback creates more backpressure and exposes the 02 sensor to the gases it normally wouldn't see.
Old Jul 1, 2004 | 01:45 PM
redevo58's Avatar
no its not due to the stock cat-back. i also have the helix testpipe along with the a down pipe and cat-back and still get a CEL. i am going to try the anti-fouler covers to see if it will work.
