Just ordered the Walbro 255 HP fuel pump, the 342 model
Old Jul 6, 2004 | 11:49 AM
93civEJ1's Avatar
Any words of advice or anything for when it comes in and I throw it in?? I will be using www.evomoto.com install for the pump. I am also running the SAFCII, but have it zero'd out because i dont have access to a wideband o2 right now. Any words from the wisdowm people??
Old Jul 6, 2004 | 11:52 AM
jj_008's Avatar
Make sure that the pump is labeled 342. Also, take your time and be easy on the plastic fittings.
Old Jul 6, 2004 | 12:15 PM
93civEJ1's Avatar
Will do that, yeah it should be the 342 since that is the kit that I ordered. Any more suggestions on this subject?? I know i may run a little more rich up top with this but that will be ok, id rather be too rich than lean with my intake. Any future damaging affects happen from running the walbro pump for a while and not being able to tune for it other than running a little more rich??
Old Jul 7, 2004 | 12:11 PM
93civEJ1's Avatar
Bump!!
Old Jul 7, 2004 | 01:47 PM
rebelzx's Avatar
It's a real easy install. I used the evomoto.com write-up as well and had the whole thing done in 30 minutes. The only hard part is getting that damn cover on and off. As long as you don't snap off any of the plastic fittings you should be ok.
