Fuel Pump - Can you replace it when the tank is full?
Old Jul 8, 2004 | 07:12 AM
TomsSound's Avatar
Do you guys think it would be a problem if I tried to replace the fuel pump while the car has a full tank of gas?
What kind of problems would arise?
Thanks
Old Jul 8, 2004 | 07:18 AM
gadsmevo's Avatar
You can do it. Just prepare to make more of a mess.
Old Jul 8, 2004 | 07:19 AM
snoop's Avatar
Wait!!
Gas will be all over your car. I would change it with 1/4 tank or less which is what I did.
Old Jul 8, 2004 | 07:21 AM
nastea's Avatar
i did it with a full tank not a big deal
Old Jul 8, 2004 | 07:22 AM
stvbreal's Avatar
I changed it with a full tank of gas. You can do it but the gas level will be right at the top. Keep some rags handy.
Old Jul 8, 2004 | 07:28 AM
SterlingEvo's Avatar
yeah, just don't smoke while you're doing it... I'd say just drive around for about 20 mins at WOT, and then do it
Old Jul 8, 2004 | 07:30 AM
93civEJ1's Avatar
I am about to do mine, either tonight or tommorow. I should have around 1/4 a tank. My car is going to run like crap from what i read.
Old Jul 8, 2004 | 07:51 AM
TomsSound's Avatar
Why is your's going to run like crap?
Thanks for the replies guys. I guess I'll wait and do it after it gets down to about half or so.
Old Jul 8, 2004 | 08:00 AM
mifesto's Avatar
no no only thing is .. since the gas is all the way up there.. you'll be touching alot of gasoline... and do u honestly want to????
Old Jul 8, 2004 | 09:40 AM
bolsen's Avatar
like oh my god! I might get gas on my hands!
Old Jul 8, 2004 | 10:05 AM
93civEJ1's Avatar
because supposively, with the pump you will run pretty rich because of the higher output of fuel. I have an SAFC, but no way to see my a/f.
Old Jul 8, 2004 | 10:10 AM
XRS-Lift's Avatar
supposedly* And yes you WILL be running even more rich than the crap factory settings. Unless ur getting ur ecu tuned or your going to retune ur safc then its a stupid move to put in a better fuel pump.
Old Jul 8, 2004 | 01:34 PM
mifesto's Avatar
i'll let u take a bath in my gas tank, have a ball....
Old Jul 9, 2004 | 09:13 PM
TomsSound's Avatar
I replaced the fuel pump today with a little under 3/4ths of a tank.
It looked like it was filled to the top. Definitely would'nt recommend anyone else trying it with more than that. The install was pretty simple. Thanks to http://www.evomoto.com's how-to.
Old Jul 9, 2004 | 11:27 PM
mifesto's Avatar
its like trying to clean the toilet with **** floating in it... flush first then clean hehe
