Help! my evo is broken.
Old Jul 16, 2004 | 10:25 PM
Hungbee112's Avatar
Sounds like your not giving it enough gas or letting out the clutch to soon to me. Especially if your reving at 2k, you need to ease out the clutch slowly for two reasons..
1. Its an all wheel drive car, which means it takes a little more effort to get going.
2. It has a fairly lightweight flywheel, which requires you to feather your clutch and get on the gas a little more than usual.
I'm not there to witness in person what your problem is, but from what you describe it sounds normal to me. I had that problem too until I learned to drive the wild beast.
Old Jul 16, 2004 | 10:26 PM
dizzigital's Avatar
how do your brakes feel? do you feel you have to have an extremely strong left leg went going into first from a stop? does the brake pedal feel very hard?
Old Jul 17, 2004 | 12:45 AM
MitsuJoe's Avatar
sorry about saying it could be the clutch!
Old Jul 17, 2004 | 02:55 AM
3K's Avatar
3K
Originally posted by: Hungbee 112Sounds like your not giving it enough gas or letting out the clutch to soon to me. Especially if your reving at 2k, you need to ease out the clutch slowly for two reasons..
EXACTLY!!!
Originally posted by: dizzigital how do your brakes feel? do you feel you have to have an extremely strong left leg went going into first from a stop? does the brake pedal feel very hard?
hey dizzi is this your one size fits all soluiton to every Evo problem? J/K
Old Jul 17, 2004 | 03:05 AM
dizzigital's Avatar
Originally Posted by 3K
EXACTLY!!!
hell yeah baby... just like those Starter baseball caps.
words of wisdom: there is no better advice than experience.
learn it baby. only then will you proceed in life. miniscule, childish remarks like yours above will only have you stuck in the same position throughout your lifetime. good luck.
Old Jul 17, 2004 | 03:09 AM
dizzigital's Avatar
the asian guy with the asian girl icon is correct. i was quite the tipsy one when scimming over the post, hence, responding with the solution to my recently resolved issue, looking to help out anyone else with the similar problem.
Old Jul 17, 2004 | 03:39 AM
darkjediii's Avatar
No Its not driver error, I have had 6 cars since I got my liscense all manual tranny, I have been driving manual for 9 years.
I have had a lightly modded mx6 turbo, heavily modded Prelude (racing clutch), mildly modded 04' WRX, and now the evo.
The reason i go up to 2k is because there is no way to get a smooth start from low RPMs it's almost embarrasing to start from a full stop because it looks like im about to stall. the car shakes. but no it is not driver error trust me.
Old Jul 17, 2004 | 03:44 AM
dizzigital's Avatar
try mine. if it doesn't work, talk to a professional.
Old Jul 17, 2004 | 04:30 AM
sarin's Avatar
bring it back to the dealer asap since you just bought the car less than a week. they should fix the problem.
Old Jul 17, 2004 | 04:50 AM
ducaticorse's Avatar
Exactly what I was gonna say. It's not your clutch, u would experiance te opposite, gas on high rpm and little t no movement. You're not into boost with the rpm's that low, it's not a leak. Get aquainted with the car, it sounds like you need practice and are paranoid.
Old Jul 17, 2004 | 11:21 AM
Hungbee112's Avatar
I drove other manual cars including a wrx before the evo also. The evo is by far the hardest car to drive out of all of them. It took me a while to learn not to bog the evo in first (AWD + lightweight flywheel + little power downlow = rough starts). but if thats not it ......... I would check for boost leaks and make sure your intercooler pipes are on tight.
Old Jul 17, 2004 | 10:10 PM
darkjediii's Avatar
thanks for the suggestions so far guys. i checked the hoses, it looks like one of the small hoses (the one with the larger rubber over it coming from the IC piping) was coming loose, i tightened that back up and it improved it just a bit. looks like the previous owner had some mods that they took out. I have never worked on an evo before, any other suggestions on where to look?
Old Jul 17, 2004 | 10:11 PM
darkjediii's Avatar
Originally Posted by MalibuJack
Nah, its not a clutch problem.. Take a look at your Diverter valve.. If the previous owner had a BOV or some other aftermarket parts on it, the stock valve may have been reinstalled backwards.. It sounds more like your trying to start from a roll at a RPM much lower than the car wants to go at.. but do a complete tune up on the car.. Change the oil, the plugs, air filter, etc.. check the Intercooler hoses and verify the Diverter Valve (blowoff valve) installed backwards.
You won't be able to tell much in neutral..
IF you roll off the line, load the engine, then release the clutch suddenly, do the RPM's drop to the point of nearly stalling?
how can I tell if the diverter valve has been installed backwards? what does it look like and where is it located?
Old Jul 19, 2004 | 06:50 AM
darkjediii's Avatar
No it didn't do that. when i start from a roll its not as noticable, you barely feel the shudder but its still there.
Old Jul 19, 2004 | 09:42 AM
Hungbee112's Avatar
https://www.evolutionm.net/forums/sh...ght=blow+valve
Check this thread out it might help you with the diverter/blow-off valve.
MagEvoVII
14
Mar 5, 2005 05:30 PM
MagEvoVII
Aug 12, 2004 10:27 AM
EvoInSoCal
Jan 26, 2004 09:33 AM
AltezzaRoku
Jan 9, 2004 02:22 PM
