WTF my car is bone stock and still have problems WTF!!
Old Jul 17, 2004 | 09:59 PM
batty's Avatar
Ok here is the deal I barely ever use my EVO 10000 miles its been a year. I seriously drive like a grandma when
Old Jul 17, 2004 | 10:22 PM
batty's Avatar
no ideas???
Old Jul 17, 2004 | 10:33 PM
evo542's Avatar
OUCH! stock you're not supposed to boost that much!! 17-19psi's should be max boost tapering down to 16-17psi be redline. you probably have a faulty solenoid valve
Old Jul 17, 2004 | 10:35 PM
SoR's Avatar
SoR
It's normal to peak at 21psi. If you have problems with boost or better - lack of it, check your hoses, there have been posts that some hoses are not clamped tight and come off and you lose boost. Try doing a search.
Old Jul 17, 2004 | 10:40 PM
SoR's Avatar
SoR
My car stock also went to 21psi for a split second
Old Jul 17, 2004 | 10:44 PM
Rollaway's Avatar
the post a while back could have been a wastgate problem and what you probably have now is a boost leak problem.. check your hoses, bov and anything else where air flows
Old Jul 17, 2004 | 10:48 PM
batty's Avatar
Well i checked all clamps, hoses etc. It does it when it wants to it seems like it. If it was a hose wouldnt it do it all the time.
Old Jul 18, 2004 | 12:02 AM
batty's Avatar
i guess it
Old Jul 18, 2004 | 12:13 AM
TurboMaestro's Avatar
welcome to my world, mine is doing the same thing, sounds like. check my thread
http://www.forums.evolutionm.net/showthread.php?t=89642
and this thread, all similar problems
http://www.forums.evolutionm.net/showthread.php?t=88685
Old Jul 18, 2004 | 07:15 AM
batty's Avatar
On A side note I posted about my pulley squeaking
Old Jul 18, 2004 | 07:32 AM
batty's Avatar
here are some pics. this is fun almost 10000 miles on it and already a headache.
Attached Thumbnails WTF my car is bone stock and still have problems WTF!!-img_2739.jpg   WTF my car is bone stock and still have problems WTF!!-img_2742.jpg
Old Jul 18, 2004 | 07:37 AM
EVO8LTW's Avatar
What are you using for a boost gauge? Sure it's correct?
Old Jul 18, 2004 | 07:39 AM
batty's Avatar
Using a DEFI D Gauge its fine.
Old Jul 18, 2004 | 09:03 AM
batty's Avatar
maybe its a wastegate problem resulting in a overboost which then results in boost cut.
Old Jul 18, 2004 | 11:41 AM
MitsuJoe's Avatar
what is it that your pointing out in the belt/pulley pictures?
