WORKS vs TOMEI
Old Jul 19, 2004 | 04:22 AM
Yaroslav's Avatar
Question WORKS vs TOMEI
Help please!
Which CAMS are better and more aggresive?
May be someone has it on car. Share by your information
WORKS 269/lift...? vs TOMEI 260/lift11.5 ???????????????
Advice something[/SIZE
Old Jul 19, 2004 | 04:33 AM
asidbyrne's Avatar
Cams
FYI, Tomei Procams come in 11.5 mm lift with durations of 260/270/280 degrees depending on your requirements.
Dunno about the Works cams. But I think your setup should determin what kind of cams you want and where you wan the powerband to be.
Old Jul 19, 2004 | 12:34 PM
GokuSSj4's Avatar
have you consider Piper cams ?
265/265 11.5mm or 272/272 12.0mm
www.quatum-racing.com
Piper Rally Cam Set - EVO
The "Rally" cam set is ideal for turbo EVO's with headwork (road course, highway). They feature 265 degrees of duration with 11.50/11.50 mm (IN/EX) lift. These cams are the result of years of EVO-specific tuning and development. The cams are designed with assymetric lob profile for quick open and easy set down for the most high-lift time possible without sacrificing valve seat life. These cams require upgraded valvespring kit to permit higher valve lift. Duration at 1mm; 217/217 deg (IN/EX).
Piper Ultimate Road Cam Set - EVO
The "Ultimate Road" cam set is ideal for stock turbo (autocross) or midrange-oriented big turbo EVO's. They feature 265 degrees of duration with 11.50/10.80 mm (IN/EX) lift. These cams are the result of years of EVO-specific tuning and development. The cams are designed with assymetric lob profile for quick open and easy set down for the most high-lift time possible without sacrificing valve seat life. These cams require upgraded valvespring kit to permit higher valve lift. Duration at 1mm; 217/211 deg (IN/EX).
Piper Race Cam Set - EVO
The "Race" cam set is ideal for turbo EVO's with full headwork and manifolds (drag). They feature 272 degrees of duration with 12.00/12.00 mm (IN/EX) lift. These cams are the result of years of EVO-specific tuning and development. The cams are designed with assymetric lob profile for quick open and easy set down for the most high-lift time possible without sacrificing valve seat life. These cams require upgraded valvespring kit to permit higher valve lift, etc. Duration at 1mm; 224/224 deg (IN/EX).
Old Jul 19, 2004 | 01:34 PM
Yaroslav's Avatar
What about WORKS CAMS?
Old Jul 19, 2004 | 01:36 PM
ez76's Avatar
WORKS uses a different system for measuring maximum lift
I am not sure if anyone has gotten an answer from about max. lift them that can be compared apples-to-apples against other Evo cams.
I am also not sure if their 274 cams are out.
Old Jul 19, 2004 | 01:58 PM
erioshi's Avatar
Try here: https://www.evolutionm.net/forums/sh...ad.php?t=86242
Old Jul 19, 2004 | 01:59 PM
DOOMID@TeamD's Avatar
Former Vendor
I have the Tomei 260 pro cams...they are awesome, idle is pretty smooth mid range and top end are incredible. I would definitely reccomend the pro cams.
Old Jul 19, 2004 | 02:10 PM
value's Avatar
Tomei came out with a few new cams also. Now you can get 260, 270, 280 duration with 11.5 or 11.8! Plan on changing springs and retainers.
Old Jul 19, 2004 | 03:58 PM
erioshi's Avatar
Value, can you PM me the specs on those cams? If you can I'll add them to the list.
Old Jul 19, 2004 | 04:14 PM
value's Avatar
Here is the PDF file http://www.tomei-p.co.jp/tomeib/pdf/19.pdf
Old Jul 19, 2004 | 05:57 PM
GokuSSj4's Avatar
wow !! didnt know Tomei made 260/260 with 11.5mm or even the 270/270 or 280/280
what can you spect out of the 270/270 with 11.5mm lift ?, of course changing the valvetrain is a must
compare to 264/272 hks cams
Old Jul 19, 2004 | 08:47 PM
marksae's Avatar
Anyone have WORKS cams and have some 1/4 times or dyno charts?
RallySport Direct
Oct 17, 2016 03:35 PM
RallySport Direct
Evo X How Tos / Installations
40
Aug 17, 2015 07:46 PM
EvowagonIX
Jul 20, 2015 05:30 PM
RavSpec
54
Jan 25, 2008 03:33 PM
500whp.com
40
Jul 22, 2006 11:58 AM
