Humidity = Good not Bad
Old Jul 23, 2004 | 05:16 AM
  #31
MayhemSi's Avatar
Also.. don't try to equate humid air w/water being sprayed on the IC because I know thats where you probably will go after my post.. the humidity is already in the air and is therefore innefective where the water sprayed on the intercooler evaporates and takes heat with it.
Old Jul 23, 2004 | 05:20 AM
  #32
MrBonus's Avatar
Originally Posted by MayhemSi
Your logic is a bit faulty because you are skipping alot of things here. I'll start simple and we can work up if you still don't get it. Humidity means less oxygen in the air which is bad for peak hp because to make hp you have to have both oxygen and fuel. This is not the same as dry air coming into the system and having water injection because the drier air still has more oxygen in it per volume then the humid air does. Also, humid air and dry air behave differently as they enter and exit the turbo and have much different heating behaviors. On top of this, humidity lowers the effectiveness of your intercooler which is again a bad thing for turbos. So no.. humidity is not good..
Yep. More oxygen is more power.
Everyone runs slower in the humidity. Anyone who doesn't believe that hasn't spent enough time around the tracks in the Mid-Atlantic.
Old Jul 23, 2004 | 07:06 AM
  #33
Noize's Avatar
EvoM Administrator
bishi,
Humidity is the enemy of performance.
Want proof? Turn off the SAE correction factor on any dyno and run the car on a humid day and then on a less humid day with the same temperature. The low humidity makes more power. This has always been true. You can tune all you want, but if you optimize the car in a less humid situation, it will make more power. Go to any dyno in the country, look at cars with lots of runs, and verify this fact for yourself.
Old Jul 23, 2004 | 07:22 AM
  #34
siantjab's Avatar
I live in the middle for FLA (I know, you're from S. FLA) and you're wrong. Did you have your evo in FLA? I have a lot of freinds that go to the track with me in their evos and you can watch the timeslips go higher with the humidity. To a degree some humidity I'm sure helps, but anything as oppressive as the humidity here (70 - 95%) can only kill compustion.
It's obvious that you're adminent about your stance here, so I don't want to start a flame war. Yes, my car was tuned (Dynoflash) for the humidity; as much as possible. But even Al insists you get the best tune at night when the humidity drops a little and so do temps. I too lived in AZ and I know what you are saying, but to make a blanket statement like "humidy is good for performance" is rediculous.
I personally can't wait till the humidity and temps drop around here; I really wanna get some 12's down on the 1/4.
Thanks for you input though.
Old Jul 23, 2004 | 07:24 AM
  #35
JDF's Avatar
JDF
Bishi,
When I used water injection, I was under the impression that:
1. water does not compress, thus I would realize a gain in compression.
2. when the water went through phase change in the combustion chamber it would carry away more heat and prevent knock.
This differs from high humidity in that water vapor compresses and does not absorb as much heat as a phase change does.
Mayhem,
You are right, but humid air does hold more heat than dry air, not comparable to liquid water though.
Old Jul 23, 2004 | 10:13 AM
  #36
NOVA EVO's Avatar
Heat robs power.
Humidity robs power.
Heat + Humidity turns a 12-second car into a 14-second car.
Summertime in Florida = Heat + Humidity = VERY BAD!
Dry, 40-50 degree days in the fall and winter in Florida = VERY GOOD!
Old Jul 23, 2004 | 11:46 AM
  #37
exhaust_note's Avatar
i was runnin 13.7 @99 in 40% relative humidity..
last nite i was runnin 14.1 @98 in 100% relative humidity...
same deal for the guy w/ the SRT-4 last nite... he 2 was runnin like ****....
the more humid means less oxygen... the less oxygen the less power.....
Old Jul 23, 2004 | 11:57 AM
  #38
YellwTyper's Avatar
Humidity is bad actually. Water is denser then oxygen,... so what humidity does is take way the amount of oxygen in fuel/air mixture. Alot of the time it really just lowers your octane rating.
Old Jul 23, 2004 | 12:00 PM
  #39
Kordwood's Avatar
Typically, temperatures are higher when there's high humidity. Maybe this theory holds out on a cold, rainy winter day, but no way in the summer.
Old Jul 23, 2004 | 03:18 PM
  #40
nothere's Avatar
guys give it up, if you tune for humidity you will get more power, but since you don't tune for humidity you loose power when it is humid. Bishi is right and so are you.
Old Jul 23, 2004 | 03:33 PM
  #41
EVOTEXAS's Avatar
Oh are you saying he is right based on the fact that your knowledge on this subject is so weak you don't know who to beleive and it's hurting your brain so much that we should all just give it up? no way. there's right and there's wrong. if you settle for wrong you have worse problems than air density. complacency kills.
it's the same principle as altitude. the higher up you are the less dense the air is. there is less oxygen per part of air. it's harder for us to breathe and it's harder for the car to breathe. you can tune to compensate but you will never make the same power at altitude or humidity as you will at sea level or less humidity. the effective altitude changes based on humidity (and temp). more humidity is the same as being at a higher altitude.
this BS theory is the same as saying that it is better to have a restrictive intake so less oxygen gets to the motor. oxygen is the only thing that burns in the air the motor ingests and if there is less air it is no different than just plain having less oxygen. we open up intakes so more air carrying the needed oxygen can get in. we open up the exhaust so the motor can get rid of the used air to make way for more good air sooner. it's so basic.
this is so bunk it's ridiculous.
Old Jul 23, 2004 | 03:34 PM
  #42
MayhemSi's Avatar
find me a place with air that has a perfect level of humidity all the time and that will make some sense, though very little because it still doesn't take into account the completely different thermodynamic fluid flow of humid air as opposed to dry air as the droppletts of water hit the compressor wheel... *shrug* I'm just telling you from an engineering perspective... negative ghostrider...
Old Jul 23, 2004 | 03:37 PM
  #43
EVOSTEVO's Avatar
the colder the air the more dense the air is. humidity is very bad. in chicago you can tell the difference night and day with humidiy.
Old Jul 23, 2004 | 03:44 PM
  #44
nothere's Avatar
hey all your personal experience means squat. do a little research on the topic.
Old Jul 23, 2004 | 03:52 PM
  #45
Terry S's Avatar
I see your point Bishi.. Theoretically your correct, but tuning for a specific humidity and temperature would put people at a disadvantage once it dries out.. This would promote knock since you got all aggressive while the weather was helping. Unless they have something to tune on the fly, they would risk engine damage tuning to the specific weather of the day.. Hence again why tuners tend to tune "safely" to cover there butts. (i.e. someone in AZ was tuned at 75 degrees and 20% humidity, then went to Florida in 99 degrees and 90% humidity).
Terry S
