oil pressure sensor. Need help badly
someone please tell me where to attach my oil press gauge sensor. Its been 5 hours and im still lost after being helped. Thanks i need help badly
I've seen two ways people have hooked up their oil pressure sensor. One is at the allen bolt next to the oil filter. You will need some sort of 1/8 PT fitting adapter. The other option is using the Greddy Oil Block. I used the Oil Block option since it was the easiest. Most of the online speed shops are selling them fror $50-$60. The oil block has two 1/8 PT taps and one M12 tap.
http://www.rallysportdirect.com/shop...roducts_id/736
