buschur racing sheet metal intake manifold
hey i was wondering, buschur's other products tend to get a lot of attention but what of the sheet metal intake mani, how does it compare to others, and what even makes a good intake mani.
oh and does the mani mate well with the br upper ic pipe?
The BR upper i/c pipe has to have 1.25 inches cut off the lower end of the upper section of pipe. We will do this for free if you send you pipe to us and then we can re-bead roll it for you.
Changing to a sheetmetal intake is like changing to a set of larger cams. The power band gets moved up with the short runner intake.
I would recommend only using the sheetmetal if you have a stand alone. The reason being there is no prevision for the factory MAP sensor or the factory EGR valve.
David Buschur
www.buschurracing.com
David Buschur
