whining noise
Old Aug 3, 2004 | 12:23 PM
turboevoct9's Avatar
whining noise
i am getting this whining noise coming from my driveshaft or transfer case. If anyone knows or experienced this **** of a problem. The car was running fine with the single plate exedy for about a week. i think its the input shaft bearing that went out.
Old Aug 3, 2004 | 12:37 PM
evoguy's Avatar
T-case... Happened to me.
Old Aug 3, 2004 | 12:43 PM
evoinit's Avatar
t case mine happened also
Old Aug 3, 2004 | 12:50 PM
did you guys buy brand new one? and was the whole transfer case jacked up or was it the gearing?
Old Aug 3, 2004 | 12:53 PM
evoinit's Avatar
warrenty coem on now
its a brand new car
and i had a clutch flywheel and intkae
Old Aug 3, 2004 | 01:21 PM
Where are you located?
Old Aug 3, 2004 | 01:22 PM
evoinit's Avatar
nj
Old Aug 3, 2004 | 03:01 PM
turboDan's Avatar
Easy to eliminate input shaft bearing noise,just put car in neutral,idling and see
if noise is there,then push in clutch,wait about 5-9 seconds with clutch still depressed,if noise is gone then it could be input shaft bearing,or any other bearing in trans for that matter,if noise still there with clutch pushed in,then not
any trans bearings,but possibly a throwout bearing noise.Hope this helps
Old Aug 3, 2004 | 03:04 PM
YellowFever's Avatar
please make sure there is oil in it
