Torque spec. for the cams
Old Aug 5, 2004 | 04:17 AM
PHILLY EVO's Avatar
Does anyone know off hand the torque spec for the cams bolts on the evo and if there is a pattern to follow.
Old Aug 5, 2004 | 05:42 AM
Stinkapuss's Avatar
14-15 ftlbs for the journals.
Old Aug 5, 2004 | 08:10 AM
Yaroslav's Avatar
What About Works Cams 269?
Old Aug 5, 2004 | 08:13 AM
Quickshift's Avatar
All should be the same, I did mine at 14.5 ft lbs.
Old Aug 5, 2004 | 12:17 PM
erioshi's Avatar
What he said!
I don't remember an order being specified, but I worked the caps for each cam down evenly across the engine. I started with the the two ends and then alternated towards the center. A turn or two on each cap bolt before moving to the next. I switched to about 1/2 turn each when the caps were close to the head.
My cams now have a good 2K miles on them, two dyno sessions and a full day of track time (I'm a road course junkie) on them and have been flawless.
Old Aug 5, 2004 | 02:00 PM
PHILLY EVO's Avatar
Ok thanks guys
