Hks Eids
Old Aug 13, 2004 | 11:46 PM
SlowCar's Avatar
Hks Eids
Just wondering if anyone has tried this...
"The HKS Electronic Idle Stabilizer (EIDS) smooths the signal from the MAS when running blow-off valves that are vented to atmosphere (non-recirculation). This helps avoid rapid changes in metering that can cause idle stability issues.
Recommended for use on the US-Spec Evo 8 SSQV kit or any BOV run in a VTA setup that relies on the MAS for engine management metering. Fits Lancer Evolution VIII"........from the lancershop.com?
Old Aug 14, 2004 | 01:40 AM
areet's Avatar
Try searching, there are a few threads about it. More information than I'm willing to type out again except that it works, but should be disabled for dragstrip runs as it will raise your time (at least with me).
