hks rs intake question?
Old Aug 16, 2004 | 02:59 PM
sloty27's Avatar
i just install the hks rs kit 3 days ago with a mr bov too..and today i was goin up my friends driveway and it stalled and i was on the clutch then i try to start it then i had problem starting it and then when i got it started my check engine light went on..ne1 know wuts wrong??
Old Aug 16, 2004 | 03:06 PM
EVOSTEVO's Avatar
you have crankwalk. check your mas connection and reset the ecu it should fix it.
Old Aug 16, 2004 | 05:13 PM
MAVERICKVIII's Avatar
The aftermarket intakes will do that to your car. In the low Rpm range it will want to bog down and if you don't catch it your car could stall. Just reset your ecu.
Old Aug 16, 2004 | 06:55 PM
sloty27's Avatar
is that were i got the cel from??
Old Aug 17, 2004 | 10:27 PM
spoon80's Avatar
it happened to my car as well, and after i reset ecu..it still does sometimes..but not very often. one day after stalled, check engine soon light came on and 2~3days later i was on the way to autozone to scan, and..suddenly..it went off..what the???...so far..it's okay..you should wait a little bit or disconnect your bettery for a min or two..^^
Old Aug 18, 2004 | 02:36 AM
Wizard_of_Evo's Avatar
what cel are you pulling?
