blitz sbc-id owners.....
what are you guys settings... i had mines at 20 gain 60 set before i put my clutch in and was holding 20 lbs strog. i checked all the lines clams and hoses... now im only hitting 16-18 lbs
.... anyone got any advice or settings i should try.. highest i can get so far without going over 65 set is 18
..... any one??????????
could it be temps outside?.... it may also be that your stock clutch may have been slipping or osmething, i just say retune...
When I had my SBC in it was set at like 25 or something for the gain, and the set was around 50 i was only running 18-19psi
gain 15-20, what you're seeing is probably the spike to 20psi..
60 with everything stock should get you around 16-18 psi ..
to get your 19psi, it's 63 set .. and 65 set should get you around 22-23psi ..
that's with aftermarket exhaust and downpipe ..
man i got some crazy settings 32 gain and 68 set.... hitting 20 lbs.... for some reason i sdon't think thats right..... maybe its the heat.....
mine's set at auto right now and its working pretty good for me and i got it set to the rest of the settings.i had it on 19/20/21 and the gain is on 5. i have a reflash alsready so i had to make the sbc work with it.
