Exhaust Manifold Thread
Old Dec 2, 2004 | 07:03 PM
  #46
chapter8's Avatar
Invidia
Price:TBA
Release date:soon
Material:Stainless unknown grade
Old Dec 2, 2004 | 10:42 PM
  #47
bo0oost's Avatar
Invidia looks sweet!
Old Dec 5, 2004 | 10:04 PM
  #48
MitsuJoe's Avatar
Although Zeus you said you had your coated...wouldn't that help make it stronger?
Old Dec 5, 2004 | 10:13 PM
  #49
Zeus's Avatar
Due to the polishing compound "cooking out", the coating pealed after a week or so... I was told after the fact that if I had the manifold heat cycled, that it should not have happened. I was offered a re-coat at the coater's expense. I've not taken the time to pull it off and take him up on it.
Old Dec 5, 2004 | 10:18 PM
  #50
johnnysixer's Avatar
Heat cycled? Whats that?
Old Dec 6, 2004 | 03:10 PM
  #51
EFIxMR's Avatar
i can vouch for the full race manifold. i have their honda top mount in my possession and it is super quality and guaranteed not to crack. compared to manifolds without merge collectors we've seen gains of 20-30 whp in the mid & top end. not sure how that translates to evo stuff though.
Old Dec 6, 2004 | 03:41 PM
  #52
bigyellowevo's Avatar
I had the full race manifold on my old turbo honda as well, and it's worth every dime.
Old Dec 14, 2004 | 09:39 AM
  #53
WildRice's Avatar
john.. heat cycling is just what the name implies, you bring the unit to extrme operating temperatures hold it for a while then let it cool. This cycle is repeated until contaminates are burned or evaporated from the metal. It also tends to help relieve stresses that have been introduced by the welding process during fabrication. It can be done on the engine or artifically.
hey Zeus.. temp cycling.. now there is a job I haven't done since my areo space days with the HP 5060 Cesium Freq. Standard.
Old Feb 10, 2005 | 05:28 AM
  #54
93civEJ1's Avatar
To those with DNP manifold and aftermarket kits, such as the ATP that bolt up to stock flange, will the DNP be strong enough to support a bigger turbo and also not crack?
Old Feb 10, 2005 | 08:37 PM
  #55
EvO6-RS2's Avatar
My DNP manifold cracked in the centre, not bad, but has cracked...only 5-6 months old. So I agree with those that say "all tubular manifolds crack" & life goes on.
Respec
Old Feb 10, 2005 | 08:45 PM
  #56
RnR Racing's Avatar
The DNP uses thin wall 304SS so I would expect those to crack.
Old Feb 10, 2005 | 10:01 PM
  #57
Zeus's Avatar
Respec
It would be interesting to know... were you running the OE O2 housing, or an after market one with that manifold?
Old Feb 11, 2005 | 12:27 PM
  #58
EvO6-RS2's Avatar
Zeus,
I was using an aftermarket O2 housing...Y u ask
Old Feb 11, 2005 | 01:06 PM
  #59
evoviiiyou's Avatar
I cannot load the same pic again but here is link to thread, Check Out My Custom Header and Turbo Install!
Old Feb 11, 2005 | 04:11 PM
  #60
marksae's Avatar
The stock o2 housing has a tab that mounts to the engine block. This actually supports the weight of the turbo. All the aftermarket o2 housings I've seen omit this support bracket. Without the support, all the weight of the turbo, o2 housing, and downpipe hangs off the manifold and subjects it to a lot more stress. This may have accelerated your manifold cracking.
But, DNP also makes an o2 housing that doesn't use that support either.
