What is the best way to modify an EVO8 for power and relaiblity
Hello I do not own a EVO but I am here to try to find out some information about one for someone.
Basically I need to know what it would be the bottom line best parts for this car speaking of strictly only engine performance. Money is not a factor for this guy. (I wish I could say that about my own car.
) But anyways what would be the best way to go about this in stages?
State One I am asuming it would be simular to any other Turbo car:
Intake, upgrade FMIC, Downpipe, Exhaust, High flow cat etc.
Stage two
Clutch, boost controller, metal headgasket etc etc etc
Am I on the right track? Which brands are the best and could you guys help me lead this guy in the right direction. Sorry about the vauge question.
) But anyways what would be the best way to go about this in stages?State One I am asuming it would be simular to any other Turbo car:
Stage two
It depends on how much power ypu are looking for. An exhaust, cams, fuel pump upgrade, boost controller and/or some type other type of engine management would be a good start. A clutch not long after that. Look at Vishnu or Works if you want a package deal. Other than that the usual quality brands are good Blitz, HKS, Apex'i and so on. Search around there is alot of good info on here.
Stage two
Stage two
"What is the best way to modify an EVO8 for power and relaiblity"
The less you do to your car, the more reliable it is. If I had extra cash I would do AEM(tunning from turbotrix), 3" turboback exhaust, EBC, upper intercooler pipping and filter. This should give you somewhere between 330-350+awhp. That's plenty fast and should be very reliable.
330-350whp w/o cams??? I don't think so. You better put cams, injectors, headstuds, and fuel pump in that list.
If you do some searches you will see that regardless of the amount of horse power you are looking for, the EMS is a great way to go if you have the money. Total tunability (timing, boost, a/f, etc.), which is important for things like cams that would throw the timing off. But basically if you do a couple searches and spend some time on the board you will get a good idea of what kind of mods the faster cars are running. Good tuning is also important. FWIW.
More to least safe in my subjective opinion:
1. Some sort of engine management (MBC = death in untrained hands i.e. not reliable). Look for some sort of piggy back device or a reflash.
2. Turbo back exhaust (most tuners have said intake side of things is pointless but the debate continues)
3. Fuel pump (for reliability)
4. Cam gears
5. It goes on and on injectors, turbo, etc
4. Cam gears
One more thing to add that should make a difference as well: I've heard from other threads that TurboTrix has a pretty conservative dyno so it makes numbers like that just that much more impressive. I am worried about passing emissions though, which is also something to be considered (no OBD-II plug). You could replace the EMS with the stcok ECU for emissions but I am not sure the car will even run with some power mods (cams, and maybe the MAP conversion? etc.). If anyone has any experience with this let me know, and I'm sure it would be helpful here as well. JMO.
Hooptie157, there are several people here that dyno'd 350+awhp with AEM, 3" turboback, mbc and filter. Turbotrix tuning and AEM are an awesome combination my man.
I myself pulled 366 whp without a cat and 272's. The car right before mine pulled 353 with 264's. So you tell me how is 350whp possible w/o cams (pump gas and safe tune)?
