did anyone have a problem with hks bov vta?
Old Sep 2, 2004 | 02:42 PM
tokeone's Avatar
aside from the start up idle being a little choppy...
what adjustments did you make to the bov (tighten/loosen)?
i dont want to screw anything up with back pressure (blow off any flex, throw pressure in the engine ect)
just wondering. i got one today and that C clamp already makes me hate it.
Old Sep 2, 2004 | 03:21 PM
jcnel_evo8's Avatar
just to help start this thread going ... is there a reason you want a vta valve? It really will make the EVO run really rich at certain points, and even may stall the motor from time to time.
A good quality recirc. valve will already have quite a *pufft* sound, and allow the already compressed air to zip back around *slightly* helping spool on the turbo again.
jcnel.
Old Sep 2, 2004 | 03:45 PM
tokeone's Avatar
im gonna get a recirc flange for it, so im just VTA for the time being. i have a 1 gen bov on my eclipse that recircs and im happy with the noise it makes.
i got the kit with the upper intercooler pipe also just for looks (and hatered for mitsu flex pipe)
i was most wondering if i had to adjust the bov settings ect.
Old Sep 2, 2004 | 03:48 PM
Miss Evo 8's Avatar
Thumbs up
I have the HKS BOV. It's cool and makes a really loud noise! I bought the "kit" for the Evo which recirculates. I don't have any problems with it except that sometimes the RPM's dip way down like its going to stall, but it doesn't. I have no complaints.
Old Sep 2, 2004 | 03:55 PM
tokeone's Avatar
thanks miss evo.
i expected the rpm problem (although that can be fixed by taking out some the of "honeycombs" in the mass air sensor. or at least that was the case in 2nd gen eclipses)
but a little dip isnt so bad.
why is everyone so afraid of running rich? isnt more fuel kinda of a good thing?
Old Sep 2, 2004 | 03:56 PM
matt55's Avatar
Some thread on here said that the adjustment really does not do anything , and that was some 1 from hks , Ive adjusted the bolt on my ssbov and i have yet to see it makes a diff.
Old Sep 2, 2004 | 04:08 PM
Secret Chimp's Avatar
Moved to engine tech...
Old Sep 2, 2004 | 05:57 PM
03venom's Avatar
I run the HKS SSQV VTA and have had virtually no problems (only an occasional dip in idle). You do NOT want to adjust the screw on the back of the unit. If you already have, you can PM me and I'll walk you through setting it back to the position HKS reccomends (e.g. the one that works extremely well). Hope this helps.
This link may help you as well (has the HKS corporate response):
https://www.evolutionm.net/forums/sh...ad.php?t=88637
Old Sep 2, 2004 | 07:28 PM
tokeone's Avatar
did anyone see an increase in psi?
im running stock (well, broken factory accuator, so i have vaccum to the intake and the wastegate/turbo y'ed and plugged off until next tuesday when mitsu gets the part in)
im hitting 22+ psi in 3rd now.
Old Sep 2, 2004 | 08:54 PM
4G63 Racer's Avatar
the hks bov reacts to slow and you may get compresser surge, had one on my talon adn didnt like it so I got the type-s.
Old Sep 2, 2004 | 09:29 PM
03venom's Avatar
PM'ed you.
Old Sep 3, 2004 | 01:48 AM
tokeone's Avatar
heres my experience, merely 6 hours after instal.
i was on the way to my GFs, just gotten off the freeway, total normal driving, not even hitting boost past 10-12 psi, pull up to a light, car stalls, wouldnt restart.
luckily i rolled into a church parking lot (where i looked under the hood for any loose pipes and said, please god please god please god a few times) let it sit a few minutes and then turned the ignition while pumping the gas until it came back to life.
drove the remainder of the way to the gfs (2 blocks) and continued to put the car back to stock using a pocket flashlight in my mouth (mind you it was like 12:30am) as guidance.
any ideas?
Old Sep 5, 2004 | 02:22 AM
vegeta irie's Avatar
I'm thinking of the SSQV(VTA), and have an E-manage that has the anti-stall feature what are the repercusions??
Old Sep 6, 2004 | 06:46 PM
GreedMOTO's Avatar
I had the problems with the HKS SSQ and contacted HKS directly. Click here to read their response.
https://www.evolutionm.net/forums/sh...t=hks+response
Hope that helps!!!!!!!!!
Old Sep 6, 2004 | 06:48 PM
GreedMOTO's Avatar
If you are still not happy, look into purchasing the EIDS from HKS. It's next on my list to stop the dip in engine RPM's due to to much fuel.
