Another Evo dyno'd
Old Sep 4, 2004 | 11:45 AM
stvbreal's Avatar
Another Evo dyno'd
Got the Evo dyno'd and put down some decent numbers I think.
Old Sep 4, 2004 | 11:54 AM
1NastyEvo's Avatar
Wow, good #'s dude
Old Sep 4, 2004 | 12:01 PM
Stinkapuss's Avatar
Nice, is this with ems?
Old Sep 4, 2004 | 12:04 PM
stvbreal's Avatar
Thanks.
Stock ECU using S-AFC.
Old Sep 4, 2004 | 12:29 PM
Stinkapuss's Avatar
Originally Posted by stvbreal
Thanks.
Damn, is that a 2 wheel dyno or 4 wheel? What boost and gas?
Old Sep 4, 2004 | 12:32 PM
hueman's Avatar
pump gas?
Old Sep 4, 2004 | 12:55 PM
stvbreal's Avatar
It was done on an AWD dyno on pump gas (91 octane) at 21psi.
Old Sep 4, 2004 | 01:38 PM
evo81's Avatar
what other mods are in this evo?
Old Sep 4, 2004 | 01:44 PM
stvbreal's Avatar
Buschur FMIC and I/C pipes, Helix 3" turbo back with DNP O2 housing, 660 injectors, 255lp fuel pump, Profec B set at a solid 21psi, S-AFC, HKS 272 cams with Fidanza cam gears set at -1 int. and -4 exh. , 8mm plug wires, HKS-SSQV venting with no stalling.
Old Sep 4, 2004 | 01:48 PM
Genesis8's Avatar
Very nice.....NUMBERS....
Old Sep 4, 2004 | 01:53 PM
JDM-Spec.com's Avatar
Good number, max torque at what RPM with the 272 ?
Old Sep 4, 2004 | 01:58 PM
stvbreal's Avatar
Looks like max torque was at 6-6.3k RPM if I am reading it right.
Old Sep 4, 2004 | 02:00 PM
awdmofo's Avatar
hehe if max torque is @ 6-6.3k rpm then you're not driving an Evo.
Old Sep 4, 2004 | 02:25 PM
Fourdoor's Avatar
Looks like peak torque was at around 4000 and peak power around 6000 to me.
Keith
Old Sep 4, 2004 | 03:10 PM
stvbreal's Avatar
You are correct. Sorry.
