Boost Leak Nightmare.....
Originally Posted by GOKOU
I think my DP and lower intercooler pipe may slightly be leaking but not sure if there's a way to tell for sure.
Originally Posted by mike 99gsx
If you pressurize the system at the compressor housing, then you would be able to detect any leak from the compressor housing to the intake manifold (so this would cover the lower IC pipe). Where are you pressurizing the system at?
Thanks to everyone for the help. I've fixed the leaks, the ones that I was able to hear and see anyway. I think my DP and lower intercooler pipe may slightly be leaking but not sure if there's a way to tell for sure.
You guys do realize this post started in Sept. 16 2004
You also will need to disconnect and plug the pressure source to your boost controller or else it will begin to bleed off the pressure after around 15 PSI.
Okay to clear it up the impossibility to have all valves closed at #1 TDC
#1 TDC (comp)
#3 BDC (intake)
#4 TDC (exh)
#2 BDC (power)
Now look at HKS cam specs @ 1mm
intake cam 272
Open ATDC 1 degrees
Close ABDC 35 degrees
exhaust cam 272 @ 1mm
Open BBDC 34 degrees
Close BTDC 0 degrees
Valves open with engine at TDC #1
intake #3
exhaust #2
That's 4 open valves.
#1 TDC (comp)
#3 BDC (intake)
#4 TDC (exh)
#2 BDC (power)
intake cam 272
Open ATDC 1 degrees
intake #3
exhaust #2
fabiano
22
Jul 21, 2016 09:38 AM
AdamRA
Aug 30, 2010 08:09 PM
