Cams question
Old Sep 19, 2004 | 10:07 AM
Hatorade's Avatar
Cams question
Ok. I know what they do. But I've never installed or removed cams before. I'm seriously considering getting a set, but when emissions test time rolls around, I worry about the hassle of having to switch them out.
Now, I've got a UTEC. I was wondering if a tuning map could be made to keep things at an acceptable level, without removing the cams. Or would that just make the car run really terribly?
I figure getting them swapped back and forth would be a huge pain in the ***, so this is why I ask.
Old Sep 19, 2004 | 10:19 AM
gnulooks's Avatar
You need to clarify whether you are talking about cam gears of cam shafts. I have heard of many guys passing smog with cam gears. As far as cam shafts go, I am have not heard of anyone posting smog results as of yet...
Old Sep 19, 2004 | 10:31 AM
MalibuJack's Avatar
Yeah, for many of us we haven't been required to get a smog test done yet. However with the UTEC, you should be able to program a map that would pass emissions, in closed loop operation the factory ECU should compensate ok, I think the key may have to do with reducing cam overlap with adjustable timing gears. But at settings under load, you can do a low emission map with low boost and fairly lean and close to stock timing. I'll know early next year when I have to go through it.
FWIW the tuning map I had done with the utec and a fairly stock engine did pass when we tested it for the hell of it.
Old Sep 19, 2004 | 06:54 PM
Hatorade's Avatar
Yeah, right now I'm pretty close to stock. I do have a Buscher turboback with the highflow cat, and a K&N drop in, but that's it. I guess I'll just have to wait and see what happens when people's 03's start having to get tested.
When I said cams I meant shafts more or less, with regard to emissions. I don't see myself doing one without the other, though, really. Still, I've got my fingers crossed for a non-swapping workaround. I don't want to have to blow a whole weekend for an emissions test that takes 10 minutes, otherwise.
