Tranny TSB? Where?
:confused:
So ah...i've seen people post stuff bout some TSBs for the transmission... those are from mitsu themselves right? I went into the dealership and asked about TSBs on evos and all they told me was the fan controller. I dont get it =/ {pcfreak} |
I think they have TSB's mixed up with recalls
Mitsubishi is a bunch of scumbags....
Here is the TSB#0322001 Technical Service Bulletins Summary Make: MITSUBISHI Model: LANCER Year: 2003 Service Bulletin Number: 0322001 NHTSA Item Number: 10005282 Summary Description: NEWLY CONFIGURED 5TH GEAR SYNCHRONIZER SLEEVE FOR 2003 LANCER EVOLUTION MANUAL TRANSMISSION. *PH If you want a copy i can email you |
That would be awesome, someone sent me something about the 2-3 synchro already, but let me pm you my email.
Thanks alot guys! |
if your warranty's done, can you still get tsb work done?
you should still be able to, TSB's have nothing to do with warranty... |
is there a general listing of all the TSB's for the EVO, i searched around but could not find anything...thanks
My car is still under the warranty period but they are denying me b/c of mods....
i am currently fighting with Mitsu right now..... fun fun |
tsb's are not recalls, you cant force them to work on the car with a tsb in youre hand..
I had the 5 gear/syncro, and the reverse idler gear assembly replaced under the TSB for each. I didn't have any problems from Mitsubishi other than waiting for backordered parts. They even gave me a rental while they had my EVO.
Good point....however it does help knowing what is wrong with the car
Here is what I had:
TSB 1(5th Gear Syncro). Severe grind when changing from 4th to 5th gear. TSB 2(Reverse Idler Gear assembly). Grind when putting car into reverse and a loud rattle when the car is idling out of gear with clutch out. |
Redcloud.....2 questions
do you have a copy of the reverse idler? What dealer did you go to that did your car with mods? |
I'll look for it! I file everything!
I went to Younger Mitsubishi in Hagerstown, MD. My mods or warranty were not even mentioned as these issues are TSBs. I now have 99K miles on my EVO! |
Your a lucky guy....lol i am getting my ballz busted to no end. i am up to the regional rep right now.
