-   Evo Engine / Turbo / Drivetrain (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain-22/)
-   -   How come the DSM 20G didn't surge? (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain/163232-how-come-dsm-20g-didnt-surge.html)
inariv5573 Oct 9, 2005 07:54 PM
With all the talk about the Evo 20G surging, how come the popular 20G used in the old DSM's had no surging issues? They can't be different. :confused:
Elitist Evo Oct 9, 2005 08:12 PM
One it was a true 20G, larger comprssor housing and larger exhaust housing and most were EXTERNALLY gated so it could also flow more exhaust and have superior topend but added LAG. This 20G has a tiny hotside in comparison and is internallgated. So it;ll surge
If you even THOUGHT of running a 20G internally gated, it was boost creep.
inariv5573 Oct 9, 2005 08:15 PM
Gotcha, thanks. I guess converting the Evo 9 turbo to a 20G would theoretically solve this? Being it has a larger compressor housing.
Elitist Evo Oct 9, 2005 08:35 PM
idk, maybe? I blame the exhaust housing. It needs to flow more, adds lag but adds power
Zeus Oct 9, 2005 08:46 PM
Same turbine housing... same problems.
Evo#1 Oct 9, 2005 09:51 PM
Have you guys experinced the surging yourself, and does it always occure with the 20g..
I was thinking about getting it ( cheap turbo with good gains ) but all this talk about surging is scaring me
MalibuJack Oct 10, 2005 07:23 AM
I'm thinking its more about the adjustment.. Even the stock turbo surges with some of the aftermarket DV/BOV's out there..
If I recall the "True" 20G hotside, and the Evo hotside are roughly the same size.. Part of the problem is the fast spool and high boost levels we run on our cars.. You have to really carefully adjust your DV/BOV to vent easily at part throttle, while holding adequately for the boost you run..
David Buschur Oct 10, 2005 07:48 AM
First off the original DSM 20G had a smaller turbine housing than the EVO's turbine housing. The compressor cover I believe to be the big difference and that is being worked on as we speak.
David Buschur
www.buschurracing.com
RyanM Oct 10, 2005 09:55 AM
There is a link buried here somewhere showing the Evo IX turbo vs the Evo VIII turbo, it appears to be a much larger compressor cover. I'm still searching for it...
Nez136 Oct 10, 2005 10:13 AM
im really starting to believe that it is not worth the money upgrading our stock turbos to a WR or a 20g, not trying to dis Forcedperformance Or David, but you can almost achieve the same results w/ a 10.5 hotside stock turbo. i mean there is always something, i've seen dyno numbers on a WR and i dumped that idea, but now the WOT surge w/the 20G...i mean i don't think there is anyway around the 16g anymore thats worth the money unless you upgrade the full package(AMS, Vishnu, Ect.)
Soon2BEVO Oct 10, 2005 10:29 AM
Im too skepticxal to buy a 20G also because of the surge issue.
Can you buy the EVO IX compressor housings yet from Mitsu? maybe that could be a fix - it seems to be much larger!
RyanM Oct 10, 2005 10:42 AM
I've been trying to track down the part number, no luck so far.
inariv5573 Oct 10, 2005 12:04 PM
So I guess it's better to stick with the stock BOV with the 20G? Especially if I am running only 19psi.
Creamo3 Oct 10, 2005 12:45 PM
Or to run one that is adjustable.
Soon2BEVO Oct 10, 2005 01:45 PM
Creamo, can you comment on this surge isue since you have the 20G? Also hows spool, I see you have the TME version which I would want...
