Stock Vacuum at idle
Hey guys, I just installed a boost/vacuum guage. Right now the car idles at 10-12 mm/hg of vacuum. Im wondering if this is normal because my last car idled at about 20 mm/hg. I also have 272 cams, I think that might play a factor.
Before cams, i was at about 15ish. Now i'm right around 10.
So Im good then? Nothing to worry about?
no
I would say you're right on. I'm no expert, but i would say you have nothing to worry about.
I love not having anything to worry about! Thanks :thumbup:
Cams make a difference. After my Jun 272's and race port and polish headwork my vaccuum at idle is only ~ -4.5psi
I have gsc 272s and vacum is between -10 and -13
HKS 272's and am around 10-11 mm/hg of vacuum.
Not to flame on en1gama19 but how can your vacum be 1.4 PSI? Is that right or do you need a new gauge? |
FYI:
This is HIGHLY dependent on your altitude. Stock, I saw -17in hg in chicago, -12 in hg in Albuquerque, and -7 in hg at 11000'. EDIT: Chicago - 600' Albuquerque - 6500' d |
So which one is better high or low vaccum? :D Indication of vaccum leaks?
Generally a higher vacuum (more negative pressure reading) is better as it indicates a higher energy potential in the intake. In other words, the air is getting moved into the engine with greater force. With a longer duration cam, the potential goes down slightly, but the air has more time to enter and evacuate the engine -- thus higher flow.
d |
Stock I pulled every bit of 20. Now w/ my 272/264 setup I pull between 15 and 18. I am down here in Auburn/Al, so I would assume I am not that far above sea level.
Generally speaking you want between 15in/hg and 20in/hg (.51bar-.68bar). Normally if your vacuum is lower than that, you may have cam timing issues. Don't forget that most fuel pressure regulators (including ours) need at least 15in/hg to operate properly at idle.
Darin |
Not to flame on en1gama19 but how can your vacum be 1.4 PSI? Is that right or do you need a new gauge? Not 1.4psi, - 4.5psi. Read it again ;) |
