Stock Vacuum at idle
Hey guys, I just installed a boost/vacuum guage. Right now the car idles at 10-12 mm/hg of vacuum. Im wondering if this is normal because my last car idled at about 20 mm/hg. I also have 272 cams, I think that might play a factor.
FYI:
This is HIGHLY dependent on your altitude. Stock, I saw -17in hg in chicago, -12 in hg in Albuquerque, and -7 in hg at 11000'.
EDIT:
Chicago - 600'
Albuquerque - 6500'
d
EDIT:
Chicago - 600'
Albuquerque - 6500'
d
Generally a higher vacuum (more negative pressure reading) is better as it indicates a higher energy potential in the intake. In other words, the air is getting moved into the engine with greater force. With a longer duration cam, the potential goes down slightly, but the air has more time to enter and evacuate the engine -- thus higher flow.
d
d
Generally speaking you want between 15in/hg and 20in/hg (.51bar-.68bar). Normally if your vacuum is lower than that, you may have cam timing issues. Don't forget that most fuel pressure regulators (including ours) need at least 15in/hg to operate properly at idle.
Darin
Darin
Originally Posted by Deepseadiver
HKS 272's and am around 10-11 mm/hg of vacuum.
Not to flame on en1gama19 but how can your vacum be 1.4 PSI? Is that right or do you need a new gauge?
Not 1.4psi, - 4.5psi. Read it again
Indication of vaccum leaks?
