water pump went out AGAIN
so i was driving around the other day, and i noticed it was overheating, so i pulled over and found out there was no coolant in it at all, and wondered wtf was going on, i had just gotten back from my vacation and it was sitting for 3 weeks i have no idea how the hell it could have drained, but the first time it went out was when i took it in to get the recall done, becuase it started to leak coolant from the oil cooler line, but it ended up being the water pump, and it was only about 2 months ago, so i took it in today and they told me that it was the water pump again, and my car only has 12k miles on it....anybody know wtf is going on...thanks
defect!
Here: Make : MITSUBISHI Model : LANCER EVOLUTION Year : 2005 Manufacturer : MITSUBISHI MOTORS NORTH AMERICA, INC. Service Bulletin Num : 115 Date of Bulletin: APR 01, 2005 NHTSA Item Number: 10015713 Component: ENGINE AND ENGINE COOLING:COOLING SYSTEM Summary: PREMATURE WATER PUMP FAILURE. MITSUBISHI TECH TALK. TO ALSO INCLUDE 2004 MITSUBISHI LANCER EVOLUTION. *TT PS: Have them do a compression/leakdown test!!!!!!!!!! |
Is this affecting a certain range of VIN numbers?
Originally Posted by EVIL_EVO_VIII
This has happened to me 2 times already! Theres a tsb out for this issue on 2005's . The 2nd time it caused a blown head gasket, lucky enough everything else was fine. Take it to the dealer
Here: Make : MITSUBISHI Model : LANCER EVOLUTION Year : 2005 Manufacturer : MITSUBISHI MOTORS NORTH AMERICA, INC. Service Bulletin Num : 115 Date of Bulletin: APR 01, 2005 NHTSA Item Number: 10015713 Component: ENGINE AND ENGINE COOLING:COOLING SYSTEM Summary: PREMATURE WATER PUMP FAILURE. MITSUBISHI TECH TALK. TO ALSO INCLUDE 2004 MITSUBISHI LANCER EVOLUTION. *TT PS: Have them do a compression/leakdown test!!!!!!!!!! thanks, i checked to make sure they're was no coolant in the oil, but i didnt know exactly what to look for lol, its at the dealer right now, and i'll call them tomorow and ask them to do a compression/leakdown test |
i'm on my second pump as well. either the freeze plug or the water seal blow out from cylinder pressure getting by the headgasket while under boost. the best thing would be to resurface that head and throw some arp's in there since it overheated.
Is there a "tell" that the water pump is going out that I could notice before some catastrophic failure? Would I be able to hear it under acceleration?
this really concerns me. i take my evo on extended road trips frequently. i'd hate for this to happen to me out in the middle of nowhere.
i didnt hear anything, it just started leakin coolant from the passenger side up front, took it to the dealership and it was the water pump |
its the waterpump freeze plug that blew out. Happened to me on my 05 with just over 800 miles on the car. Thats what the TSB is for.
Im guessing this is only a concern with the 05+ correct. I havent heard of this issue on 03 or 04's.
This has happened to me 2 times already:crap: |
what a crock! Man thats a gay thing to have happen.... thats a serious issue that can put your motor up in lock if your paying attention to the temp gauge for a short period especially in warmer climate areas.
