water pump went out AGAIN
so i was driving around the other day, and i noticed it was overheating, so i pulled over and found out there was no coolant in it at all, and wondered wtf was going on, i had just gotten back from my vacation and it was sitting for 3 weeks i have no idea how the hell it could have drained, but the first time it went out was when i took it in to get the recall done, becuase it started to leak coolant from the oil cooler line, but it ended up being the water pump, and it was only about 2 months ago, so i took it in today and they told me that it was the water pump again, and my car only has 12k miles on it....anybody know wtf is going on...thanks
Here:
Make : MITSUBISHI
Model : LANCER EVOLUTION
Year : 2005
Manufacturer : MITSUBISHI MOTORS NORTH AMERICA, INC.
Service Bulletin Num : 115
Date of Bulletin: APR 01, 2005
NHTSA Item Number: 10015713
Component: ENGINE AND ENGINE COOLING:COOLING SYSTEM
Summary: PREMATURE WATER PUMP FAILURE. MITSUBISHI TECH TALK. TO ALSO INCLUDE 2004 MITSUBISHI LANCER EVOLUTION. *TT
PS: Have them do a compression/leakdown test!!!!!!!!!!
Originally Posted by EVIL_EVO_VIII
This has happened to me 2 times already! Theres a tsb out for this issue on 2005's . The 2nd time it caused a blown head gasket, lucky enough everything else was fine. Take it to the dealer
Here:
Make : MITSUBISHI
Year : 2005
Here:
Make : MITSUBISHI
Year : 2005
thanks, i checked to make sure they're was no coolant in the oil, but i didnt know exactly what to look for lol, its at the dealer right now, and i'll call them tomorow and ask them to do a compression/leakdown test
i'm on my second pump as well. either the freeze plug or the water seal blow out from cylinder pressure getting by the headgasket while under boost. the best thing would be to resurface that head and throw some arp's in there since it overheated.
Originally Posted by coffeeslug
Is there a "tell" that the water pump is going out that I could notice before some catastrophic failure? Would I be able to hear it under acceleration?
i didnt hear anything, it just started leakin coolant from the passenger side up front, took it to the dealership and it was the water pump
Originally Posted by 4rcd6
Im guessing this is only a concern with the 05+ correct. I havent heard of this issue on 03 or 04's.
what a crock! Man thats a gay thing to have happen.... thats a serious issue that can put your motor up in lock if your paying attention to the temp gauge for a short period especially in warmer climate areas.
