cam gears and 280's
What do you think, will I get same (similar) results by adjusting cam gears on my 280/280 setup as some other people on here? Right now they are set at 0/0.
I also need to know which one is intake cam and which one is exhaust cam? |
Mine are at 0/0 also, I think one cam has "more" lobes, but I cant tell you which is which. One has a "pin" also. sorry, I am 0/0 help!
I suggest you get someone to assist you with that. |
Originally Posted by Ted B
Intake cam is adjacent to the intake manifold, exhaust cam adjacent to the exhaust manifold.
uups i DIDnt think about it. So yes, consider it a joke :o . What about cam gears, would someones result be the same on the different car with same cams, in my case 280's?
I have my 280's set at -3/-3...running a flash.
I read someone on here runs +2/-2 with a huge increase in TQ and HP vs 0/0. Question is will the results be the same on the other car with those cams/cam gears?
Originally Posted by sleet
+2/0, not +2/-2.
and I'd appreciate your oppinion on it |
| All times are GMT -7. The time now is 06:21 PM. |
