feul pump
just wondering why people get bigger pumps? i searched a little but didn't find too much info. I want to know if I have a tbe, mbc, drop in, and ecutek flash, should i get a bigger feul pump for my ix and why??
thank you |
you only want to upgrade your fuel system when your mods can potentially overwhelm it. most do the fuel pump/injectors when they get to the point of cams and larger turbo. you shouldn't need it with your basic boltons.
it's $90.00 insurance for your motor.
It's not as important on the IXs as it is on the VIIIs because the pump is a little beefier, but you may want to ask your tuner before you get the tune. The issue is if a turbocharged car runs too lean, it will detonate causing major damage to the motor.
Originally Posted by stikillller
i've read that it is "insurance" for the motor but why??? will the engine with my basic mods and boosting just a tad higher not get enough gas? i thought that had to do with injectors? please explain instead of just telling me what everyone just says. if i spend money i'd like to know why exactly i need this specific application. thank you!!
