feul pump
Old Mar 21, 2006 | 09:24 AM
stikillller's Avatar
feul pump
just wondering why people get bigger pumps? i searched a little but didn't find too much info. I want to know if I have a tbe, mbc, drop in, and ecutek flash, should i get a bigger feul pump for my ix and why??
thank you
Old Mar 21, 2006 | 09:27 AM
byt's Avatar
byt
you only want to upgrade your fuel system when your mods can potentially overwhelm it. most do the fuel pump/injectors when they get to the point of cams and larger turbo. you shouldn't need it with your basic boltons.
Old Mar 21, 2006 | 09:29 AM
bluebanana23's Avatar
it's $90.00 insurance for your motor.
Old Mar 21, 2006 | 09:49 AM
i've read that it is "insurance" for the motor but why??? will the engine with my basic mods and boosting just a tad higher not get enough gas? i thought that had to do with injectors? please explain instead of just telling me what everyone just says. if i spend money i'd like to know why exactly i need this specific application. thank you!!
Old Mar 21, 2006 | 09:54 AM
TxEvo8's Avatar
It's not as important on the IXs as it is on the VIIIs because the pump is a little beefier, but you may want to ask your tuner before you get the tune. The issue is if a turbocharged car runs too lean, it will detonate causing major damage to the motor.
Old Mar 21, 2006 | 09:58 AM
jmartinez1170's Avatar
So you dont over work your fuel system if you do the car would run lien that happens your car goes boom. Thats as simple as i can say it. Its worth it if your going to upgrade with intake, tbe anything that relates to adding more power specialy cams.
