-   Evo Engine / Turbo / Drivetrain (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain-22/)
-   -   Not very impressed with Buschur's mini battery kit. (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain/200973-not-very-impressed-buschurs-mini-battery-kit.html)
Richard Sierra May 14, 2006 05:52 AM
The stock airbox does not fit very well. I was only able to get one of the two bolts in. The front bolt is a good 1/4" off. This is with the battery shoved all the way back and grinding about an 1/8" off the aluminum tray.
It also has a lot of sharp edges that look like they could chafe the wiring harness that rubs the tray. I expected a lot more from Buschur for $225.00.
smokedmustang May 14, 2006 05:56 AM
I opted for the Miata battery for 50.00. No problems there!!! I think you might have it in wrong, because I NEVER heard anything bad about their mini battery kit!! I just didn't want to pay that much for any MINI battery. the miata battery did the job for me!!.
Jasil May 14, 2006 06:34 AM
I'm not saying it's perfect it's not hard at all to install and what wires will get "chaffed" there aren't any touching the base unless you did something wrong?
EvoDan2004 May 14, 2006 08:34 AM
Originally Posted by trueno429
stop whining
relax there. for that kind of money it should not be a problem. that is y i went with nisei's mini batt kit.
Zeus May 14, 2006 08:52 AM
Shoot us a a few pics Richard... have you called Buschur yet?
If this turns into a Vendor bash... you know where this thread will go people.
feldguy May 14, 2006 08:55 AM
Mine worked fine. It wasnt 100 per-cent, but I would say 98% perfect. I noticed a few times I had it in incorrectly. Otherwise that little battery cranks and HARD
fromWRXtoEVO May 14, 2006 09:00 AM
stop whining
Let the guy give some feedback bro. Ultimately it will benefit everyone, is called constructive criticism, knowing how good Buschur shop is they will listen and try to improve their products. Is all part of the game.
Carlos
vwjeff May 14, 2006 09:08 AM
Maybe you should call Dave and not post something like this.
I don't think you are to use the stock air box with that battary kit.
WillEatUrSTi May 14, 2006 09:22 AM
I think vwjeff is right I thought it said on Buschur's website that the mini battery does not fit with the stock air box but perhaps with enough voices he would look into making one that does.
midwestmonster May 14, 2006 09:24 AM
Do any of you guys have problems with your battery not holding a charge if you don't drive your car for week or so? Mine gets very low and almost doesn't want to start.
fromWRXtoEVO May 14, 2006 09:29 AM
Yes, I had that problem.
Carlos
CarFanatic May 14, 2006 10:37 AM
ITs not ment to be used with the stock air box. MY battery dies too if I dont drive the car for a week.
midwestmonster May 14, 2006 10:38 AM
Carlos
How did you fix it? Just keep charging it or disconnect it when you're not driving the car?
smokedmustang May 14, 2006 10:41 AM
Just take off the negative terminal when not using it for a period of time I guess, or get a "trickle charger" I havent had that problem.
kf6ytc May 14, 2006 11:02 AM
mini batterys are worthless........ they don't hold a charge and the lifetime is less than a year......
