When am I going to max out the potential of my IX's turbo??
Ok, here's my question: When am I going to max out the capabilities of the stock IX turbo?
My IX is currently at 360whp (Dynojet)with exhaust, MBC, Buschur intake/intercooler and Walboro pump. 22psi on 93oct. Custom dynoflash. I'm adding headstuds, 02 housing and alky this month. That should get me to about 400whp on the stock IX turbo. Now I read that GSC is releasing 280 cams for the IX next month. If they're like most Evo cams, we can maybe expect 30-ish whp from them. That would get me to about 430whp. I'm sitting here wondering, however, if 430whp is really possible on the stock turbo, even with cams and alky. Those are stupid big numbers, but are they really possible? What I'm asking is, will the stock turbo be maxed out by the alky? And if it's almost maxed out, will the cams even be worth it? If you think it's worth waiting for the cams, then I'm gonna wait and just get tuned by Al for the alky and cams at the same time. Opinions?? |
there have been graphs with cars that have cams and the stuff you're descibing... no one has hit 430 but then again alkie hasn't been used either i don't think... do some 9 turbo searches... i know it's hard since you can't search 9 or ix.
or maybe people that reemmber the threads can link up in here. |
Here's a discussion I found about TT's 280 intake cam ("dissapointing" results):
https://www.evolutionm.net/forums/sh...ight=turbotrix Here's an IX with HKS 272 cam (382whp-392wtq without alky): https://www.evolutionm.net/forums/sh...d.php?t=199351 TT IX only made 14 more hp with a 272 intake cam: https://www.evolutionm.net/forums/sh...ight=turbotrix Most of the IX cam discussions have been limited to doing one cam. GSC is making a set of 280's. Maybe a set of matched cams will make some significant power? GSC is saying they're only making 280s because there don't seem to be significant gains with 264 or 272s on the IX. |
i would assume anytime you push the stock turbo over 25 pounds you're technically running the turbo at the limits of it's ability...........
Originally Posted by devolutionist
The alky would allow you to push higher boost levels in your car. Being that your at 22lbs now... and the stock turbo will max out at around 25lbs.... I would venture to say that if you install the alky kit, it would definately be time for a larger turbo to support the boost and DEFINATELY a tune. I think that sounds about right.
but then you power curve would look like crap.
dont max out ur turbo unless u do the engine work,,,,,u will blow the motor...thats what happend to me,,,,,,its the matter of time,, stock engine piston will crack in half ,stress adds up to the engine ....mine did last for about more than 1year....
think about long-term,,,,,and reliable ,,,, |
GSC Cam
Alky FMIC with full piping Good BOV ECU Reflash |
Originally Posted by yesevo
Max boost for the stock turbo is 25psi. Some say 30 but thats only peak and I dont suggest setting your mbc to 30.
As for your hp increase to 400whp with just arp studs and a 02 housing you are kidding yourself. You may see a 6-7whp gain with the 02 housing and the studs arent even hp altering mods. |
As for the O2 housing, I think more than 7hp will be gained. |
the answer is... soon.
| All times are GMT -7. The time now is 10:50 AM. |
